Just discovered that GT2560 A+ were produced in different version (but still with the same release/name A+)
If you are upgrading your FW and are not able to operate your BL touch correctly (still initialising at power on but not reacting to any menu command), there is a high probability that you are encountering the same issue than me (pin inversion).
To solve, edit PINS_GT2560_A_PLUS and swap the two value ( replace 11 by 32 inside IF block and 32 by 11 inside elseif)
Hope it help
Thierry
[Solved] BL touch initialising but not working
i3 B + i3 C + i3 M201 + A10 + A10m + A30
(+3 x Kossel)
Mostly PLA
(+3 x Kossel)
Mostly PLA
Re: [Solved] BL touch initialising but not working
Hello Tparent.
This is a very valuable notice.
(+3 x Kossel)
Mostly PLA
(+3 x Kossel)
Mostly PLA
