Does anyone knows details (voltage/current) about the stepper motors used with the i3 Alu?
I am using new driver boards (TMC2208) and want to adjust the motor current.
Best regards
Onki
What stepper motors are used with the i3Alu - current adjustment
Re: What stepper motors are used with the i3Alu - current adjustment
Hi.
Read the motor designation from the body, enter it here.
You can invert the dir of the motor on Firmware.
Then it will work normal.
Hi William,
the direction is OK. I just want to know the nominal current to adjust my new driver boards.
It is a regular I3 Aluminum stepper motor.
Best regads
Onki
Best regads
Onki
Each stepper motor has an inscribed type. If you don't read it and write it here nobody will help you.
