What stepper motors are used with the i3Alu - current adjustment
Posted: Mon Feb 11, 2019 9:03 pm
by onki
Does anyone knows details (voltage/current) about the stepper motors used with the i3 Alu?
I am using new driver boards (TMC2208) and want to adjust the motor current.
Best regards
Onki
Re: What stepper motors are used with the i3Alu - current adjustment
Posted: Fri Feb 15, 2019 3:57 am
by _kaktus_
Hi.
Read the motor designation from the body, enter it here.
Posted: Mon Feb 18, 2019 10:53 am
You can invert the dir of the motor on Firmware.
Then it will work normal.
Posted: Mon Feb 18, 2019 10:42 pm
by onki
Hi William,
the direction is OK. I just want to know the nominal current to adjust my new driver boards.
It is a regular I3 Aluminum stepper motor.
Best regads
Onki
Posted: Mon Feb 18, 2019 10:47 pm
by _kaktus_
Hello.
Each stepper motor has an inscribed type. If you don't read it and write it here nobody will help you.
