G2S Pro Table will not travel lower than 6.3mm
elmo40
Post by elmo40 »
I have no idea what is happening here.
I have the machine all calibrated. Every direction moves very accurately.
It doesn't matter what I do with any Z-value (in a program, in an offset, home offset, probe offset...) the machine will not get any closer than 6.3mm from the table! This is the display showing me this (which is what I can measure, too. Not like it reads one thing and is actually somewhere else)
Rather useless now...
Current settings:
Code: Select all
02:38:19.863 : echo:SD init fail
02:38:19.925 : echo:Active Extruder: 0
02:38:19.925 : FIRMWARE_NAME:V1.0.04 FIRMWARE_URL:http://firmware.ultimaker.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:G2Spro EXTRUDER_COUNT:2 UUID:00000000-0000-0000-0000-000000000000
02:38:19.925 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
02:38:19.925 : Begin file list
02:38:19.925 : End file list
02:38:19.941 : echo:Active Extruder: 0
02:39:56.366 : echo:Steps per unit:
02:39:56.428 : echo:  M92 X79.50 Y79.50 Z79.50 E48.13
02:39:56.428 : echo:Maximum feedrates (mm/s):
02:39:56.428 : echo:  M203 X1000.00 Y1000.00 Z1000.00 E100.00
02:39:56.428 : echo:Maximum Acceleration (mm/s2):
02:39:56.428 : echo:  M201 X5000 Y5000 Z5000 E5000
02:39:56.428 : echo:Accelerations: P=printing, R=retract and T=travel
02:39:56.428 : echo:  M204 P1000.00 R2000.00 T2000.00
02:39:56.428 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s),  Z=maximum Z jerk (mm/s),  E=maximum E jerk (mm/s)
02:39:56.428 : echo:  M205 S0.00 T0.00 B20000 X20.00 Z20.00 E5.00
02:39:56.428 : echo:Home offset (mm):
02:39:56.428 : echo:  M206 X0.00 Y0.00 Z8.30
02:39:56.428 : echo:Endstop adjustment (mm):
02:39:56.428 : echo:  M666 X0.00 Y0.00 Z0.00
02:39:56.428 : echo:Delta settings: L=delta_diagonal_rod, R=delta_radius, S=delta_segments_per_second
02:39:56.428 : echo:  M665 L197.50 R92.00 S200.00
02:39:56.428 : echo:Material heatup parameters:
02:39:56.428 : echo:  M145 M0 H190 B55 F255
02:39:56.428 : echo:  M145 M1 H230 B70 F255
02:39:56.428 : echo:PID settings:
02:39:56.428 : echo:  M301 P22.20 I1.08 D114.00 C1.00
02:39:56.428 : echo:Filament settings: Disabled
02:39:56.428 : echo:Z-Probe Offset (mm):
02:39:56.428 : echo:  M851 Z-3.50
elmo40
Re: G2S Pro Table will not travel lower than 6.3mm
Post by elmo40 »
I tried to compile a newer firmware but I keep getting errors.
I will try other IDE versions with older Marlin and see if anything will compile.
Plus, why does my SD card not read anything?
Is there a special format it needs?
For the compile error,could you attach the log?
For the SD card issue,you can check the fw at first.Or you can attach it we will help to check it.
