Difficult to connect the cable to LCD display board
Posted: Thu Feb 28, 2019 9:32 am
by BinhLy
The flat cable with 40 pins is so thin that I can not connect to the LCD display board. I tried many times but the cable would not stick. Anyone could help to show me how to do this.
Re: Difficult to connect the cable to LCD display board
Posted: Thu Feb 28, 2019 10:28 am
by BinhLy
I use a tape and form to push the cable against the slot. The light is now on on LCD but no text or anything, just green light. Please let me know what I did wrong.
Posted: Thu Feb 28, 2019 11:49 pm
by _kaktus_
Hello.
The FFC connector has a snap-flap flap on the hinge.
This is the black element.
Pick it up slightly to jump up.
Slide the flat FFC cable evenly into place. Close the flap.
If you fail to insert the cable correctly into the display socket, the display will not function properly.
Example picture.
- złącze_FFC_40pin.png (544.51 KiB) Viewed 6301 times
Posted: Fri Mar 01, 2019 10:35 am
by BinhLy
This picture does not look like the one on the new model A10M. The connector is really small. No flap.
Posted: Fri Mar 01, 2019 10:22 pm
by _kaktus_
Hi.
Can you take a good quality photo of this connector
Posted: Sat Mar 02, 2019 11:10 am
While kaktus is correct. You need to attach it then others can check it.
