Problem with Bed Leveling
Posted: Sun Mar 03, 2019 7:17 am
by new2geeetech
I can't get my bed level manually. I wasted several days trying to get the platform level without success. The four corners are now good but the center is still not sticking well. I did not have this problem before I disassembled my hotend due to a clog. I'm totally puzzled and at the point of giving up.
Will adding an auto-leveling sensor alleviate the bed leveling permanently?
Re: Problem with Bed Leveling
Posted: Mon Mar 04, 2019 2:49 pm
1.If you use the auto level sensor for it.
You can set the 25 points mode for it then it will work perfectly.
2.I think you should check the wheels of the x/y axis
Maybe it loose,try to tight it
Posted: Thu Mar 28, 2019 11:43 pm
by Vin
Perfect just what I was looking for!
How to set 25 points ??? 🙏
Posted: Sat Mar 30, 2019 4:22 pm
Hi,you can refer to these line:
Posted: Sun Mar 31, 2019 12:43 am
by Vin
Thanks William
i need change 3 to 5... true?
Posted: Mon Apr 01, 2019 1:57 pm
Vin wrote: Sun Mar 31, 2019 12:43 am Thanks William
How is it going on?
Did it work for your printer?
