Is there any extension cables set for the A30, similar to the 1 meter set that is commonly available for the CR-10 type printers? I ended up trying a CR-10/CR-10S set that I found on Amazon and while most of the cables are compatible, the filament sensor wire is of course missing and the two larger cables to extend the heated bed wiring and the hot end / print head wiring are not compatible as both of these connectors use a different number of pins than the A30 cables.
Any suggestions, beyond just cutting apart the cable set and soldering in longer wires?https://redtube.onl/ https://beeg.onl/ https://spanktube.vip/spankbang/
extension cables set for A30???
Re: extension cables set for A30???
The A30 uses the 4PIN Aviation plug for hotbed.
12 PIN Aviation plug for the extruder adapter.
You can refer to it then purchase the cables for the extension.
you are about to upgrade / extend high current cables, if you go for stock cables, they work well but might cause heating and breaking issues in the long run. [https://www.pornjk.com/tags/spankbang/]Spankbang [/https://www.pornjk.com/tags/spankbang/]use your current cables and get a set of thick gauge copper ribbon wire, disconnect your current jacks and rewire them with the new length and reconnect. this will give you opportunity to run the cables as you want to the length you want.
