Hi all,
I'm having a lot of trouble with my initial configuration. The X and Y homing is working fine, however the Z homing is not.
I disabled the stepper motors, and then lowered the extruder, set the bed height, then when I pressed "up" in Cura, it went up, but it never went back down. When I click the 'Home' button for Z, it just goes and crashes into the top.
Anyhelp would be amazing right now.
Initial Configuration
Re: Initial Configuration
Everytime I click home, it homes X properly, it homes Y properly, then it goes up by about 5mm on the Z axis, over and over.
Pls check the FAQ of i3 type printer at first.
Turns out I had the Z end stop plugged into the "Min End" plug on the motherboard, instead of the "Max End".
