When trying to use the homing function in repetier host the x-axis and the y-axis work fine!
But the z axis just moves down around 5centimeters and then stops for no obvious reason (it is not hitting the stopper or anything else)
I hope someone can help me I already tried changing the homingspeed
~Max
Z Axis not properly homing
Re: Z Axis not properly homing
You need to check your wire at first.
Maybe it is the wires problem.
You can attach it if you don't know how to check it.
