I cannot print with windows 10
Easy Print cannot print, the com serial port is recognized because it feels the connection signal with the PC, but when the print order prints the Geeetech i3 Pro C does not start. Is not Windows 10 a problem or a driver?
Re: I cannot print with windows 10
I think you should check your baud rate setting.
But I suggest you use repetier-host.
Attached the profile of the PROC:
https://drive.google.com/open?id=1y4epR ... GGgW_Wlhgi
Thanks man! All good now. Helped me a lot.
