printer sd card not detected in repetier firmware
lld
Post by lld »
I'm having an issue with my firmware not recognizing the sd card in the geeetech i3 prusa printer slot. The manual mentions a checkbox in the printer settings - printer tab, but nothing is showing up.
"The next check boxes define, what the printer should do, when a print is finished and if a SD card is available. If no SD card is available, the corresponding tab will not be displayed." https://www.repetier.com/documentation/ ... iguration/
Please help :)
Re: printer sd card not detected in repetier firmware
:mrgreen:
It happened that SD card slots did not work properly.
If you can check if the card detection contact in the slot is working well.
