Power Supply Issues
mgray_121
Power Supply Issues
Post by mgray_121 »
I have fully assembled the I3 Pro W but when i turn it on the power supply the led light (on the power supply) blinks green and makes a clicking sound. On the motherboard side the two led lights also blink green and nothing works. I thought maybe i had something was wired wrong but i've checked over the wiring and everything seems to be correct. The control panel lights up when i plug it into my computer but nothing else. I couldn't find anything about this problem online/the forum.
Tomyuan
Re: Power Supply Issues
Post by Tomyuan »
I think you need a multimeter.
You can use it to check the PSU output it 12V or not.
If the voltage is correct then you need to check the wires is correct.
Hi.
:mrgreen:
Tomi
this symptom indicates that the PSU is not working properly.
There is a short circuit in either the output circuit or the power supply has a defect.
:roll:
Tomyuan
Post by Tomyuan »
Hi,kaktus
:D If he/she can use the multimeter then the problem will be easy to be checked.
Fluxcore
Post by Fluxcore »
Did you check the 220/115 ac switch ?
