Suddenly stopped printing
lexis200
Post by lexis200 »
Hi all,
After many successful prints, my printer has stopped working. Previously I would stick in the SD card with the gcode file on it, navigate to the file screen, pick the file and hit PRINT. The system would heat up to the required temperatures, then start printing. Simple!
Now, it does everything up to me hitting PRINT. The nozzle and bed only heat up if I press the nozzle or bed setting icon, (both of these are now turned off by default) and turn them on. They both heat up but the print never starts. Cancelling the print sometimes makes the print head move up and down a bit but that's it. If I leave it without cancelling the print, the nozzle and bed stay hot until I cancel but the nozzle doesn't move at all.
Some answers to likely questions...
I'm using a gcode file I've used in the past that I know worked.
I've not made any changes that I know of to the settings.
I've not update the firmware from what came in the box which was the latest at the time (V1.35.56, hardware V2.1-null).
I've tried a new gcode file, and another older file that used to work.
I've tried a different SD card.
I've definitely tried turning it off and on again, multiple times.
I've hit the Factory Reset icon and reset the control box which beeps and restarts.
There is plenty of PLA and it's fed through the sensor.
Fans all seem to work.
The head can be moved around using the Move icon, so the motors all work OK.
I've searched the forum but couldn't find anything similar to my issue.l
Does anyone have any idea what might be wrong? Particularly as to why the nozzle and bed now seem to be set to manual so they don't auto heat up anymore?
Dave
Re: Suddenly stopped printing
Can you provide specific video ?Describe the specific situation in detail?
lexis200
Post by lexis200 »
Hi William, I don't really know what else to add. I can't do a video, but the below is a step by step sequence of what used to happen versus what happens now, hope it makes sense.
This is what I USED to do:
put in SD card with gcode file
Press PRINT, then pick file I want to print, then press PRINT again.
The A30 would heat up the nozzle and bed to 220 deg and 60 deg respectively (as noted in the gcode from the slicer program (Slicer Prusa edition 1.41.2+win64) then start printing.
This is what happens NOW:
Nothing happens.
Click on the nozzle or bed icons and see that the flip switches are both off, speed is on at 100%.
Flip nozzle and bed switches to on. Both heat up to 200 deg and 50 deg (despite gcode saying higher). Print head doesn't move at all. Leave for 2 hours, same thing.
Change the temps up to 220 and 60 deg. Both change, then maintain the temperature, but again no printing.
That's it really. The only thing I can guess at is that it's seeing the gcode file, but not reading it properly, so here's a snippet of one that I know used to work, but now doesn't... maybe that will help you?
Code: Select all
; generated by Slic3r Prusa Edition 1.41.2+win64 on 2019-02-10 at 18:00:15
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.40mm
; infill extrusion width = 0.48mm
; solid infill extrusion width = 0.60mm
; top infill extrusion width = 0.40mm
; support material extrusion width = 0.40mm
; first layer extrusion width = 0.72mm
M107
M117 Preheat Nozzle
;M851 Z-1.65
;M500
M104 T0 S220
M140 S60
M117 Homing
G28 ; Home extruder
;G29
M117 Close Nozzle
G1 Z5 F100;
G1 X320 Y320 F2000
M107 ; Turn off fan
; Wait for all used extruders to reach temperature
M190 S60
M109 S220
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
G92 E0 ; Reset extruder position
M117 Priming
G1 Z0.5 F100
G1 F400 E5
G1 Y150 E40 Z0.5 F2000
M117 Printing...
; Filament gcode
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusion
G92 E0
M117 Printing layer 0
; LAYER : 0
G1 Z0.360 F6000.000
; PURGING FINISHED
G1 E-6.50000 F2700.00000
G92 E0
G1 Z0.760 F6000.000
G1 X187.580 Y180.358
G1 Z0.360
G1 E6.50000 F2700.00000
G1 F1200
G1 X187.809 Y180.192 E6.52725
G1 X187.459 Y179.152 E6.63278
G1 X187.191 Y178.161 E6.73153
Hi, did you try to even if the computer can automatically print and print
if it is not a problem with the motherboard, maybe about SD read question?
:mrgreen:
lexis200, in your situation, I'd try two things. ;)
First, heat the heaters to the required temperature using the printer menu option. Verify the temperature reached with an external measurement.
Another thing, did you try to run the printout from a computer connected to the printer :?:
