How to change the motor directions on the firmware 1.38.59 for the A30 ?
Smartto motor 1.2 doesn’t connect, saying there is no serial port.
Thanks!
How to change A30 1.38.59 firmware motor direction
Re: How to change A30 1.38.59 firmware motor direction
Hi, I hope this can help you:http://www.geeetech.com/forum/viewtopic ... 17&t=60639
Thanks but it doesn't.
I finally found the solution, for those who will face the same:
Start Smartto Motor, unplug the USB cable, plug it and click connect AS SOON as you see the COM port displayed in the list.
Try it until it connects, it will says success at some point.
You can then spam click Get status until it is received, change directions, spam click set directions and apply until success.
No idea if that's a good idea, but at least the directions are good now.
It is a good thing for you.
