Start-up issues.
TechCoarse
Start-up issues.
Hey,
I dont know if anyone can help me im very new to this i just brought the Geeetech Acrylic Prusa I3 Pro B (My first 3d printer lol) so ive had it for awhile now (brought it in december last year) i built it the month after toke me a phew days then i had to shelve it as for months i was having issues with trying to get the heating in my house sorted but anyway finally got it setup today to the point where i can plug it into the pc and all that so im now trying to do the home test button thingy (trying to follow the manual has been pretty difficuilt) so i hit in the repeater host software the little house icon the nuzzle moves to the left hits the endstop and then goes down it gets about over half way (while its going down btw its squeaking a bit) and then it gets stuck hear the motor trying to pull it down with no luck ill be honest i have no idea what i have to do or where to start looking.
Any help would be so greatly appreciated!
Re: Start-up issues.
Hi, I hope this can help you: viewtopic.php?f=82&t=60931
TechCoarse
Hi, I think you can press the glass plate down and tighten the nut.
TechCoarse
Thanks for all your support so far its really getting there so i have a couple questions.
Im up to printing leveled the bed and seems fine but im getting alot of either not sticking to the bed or its not printing entirely on the bed part of it is sorta dangling off the edge.
Again thanks for your help and any advice/and or help you can give is greatly appreciated!
Maybe you need to 1. Check if the hot bed is level and level the hot bed;
2. It is necessary to ensure that the nozzle is at the normal height of the hot bed, and the best condition is that the material
coming out of the nozzle is slightly flattened;
3. Maybe the printing speed is too fast, you can reduce the printing speed appropriately;
I hope this can help you.
TechCoarse
Hey,
(okay so an edit fixed previous issue i had)
So i think im getting somewhere with the bed leveling but id like to have your opinion if i could ive got 3 images of something ive printed maybe you can tell me what caused the issues with this print im having??
This is the top of the print:
This is the bottom of it:
This is the side:
This is the side:
Hi,maybe 1. The layer height value is too high, and the layer height setting value should be less than 20% of the nozzle diameter;
2. The print temperature is too low, you can try to increase the print temperature.
TechCoarse
Your help has been great pretty much all sorted and such now the only other issue's i have is the print is of centre so if you print larger jobs it sorta prints off the plate and when printing it seems my extruder is clicking so im trying to adjust the vref of the stepper motor but i have no clue which driver is for the extruderWilliam wrote: Sat May 11, 2019 9:37 am Hi,maybe 1. The layer height value is too high, and the layer height setting value should be less than 20% of the nozzle diameter;
Thanks for all the help!
Hi,you said you need to adjust the stepper board voltage, you can reference board voltage range inside the picture: http://www.geeetech.com/forum/download/file.php?id=1592
