a30 tmc2100
a30 tmc2100
hello friends, install the tmc2100 drivers on my a30 printer, start printing well but after a while I see that it loses steps, my question is, I must leave the jumpers or I must remove them, or there is something else I should do, I need to put some driver that does not make as much noise, since I have the printer in my room, thanks
Re: a30 tmc2100
Hi, if you think it is too noisy, you can replace it to TMC2208, for TMC2208:0.8~0.9V is ok. If it allows, you'd better add the heat sink for TMC2208(It will overheat if you don't do anything)
