switch a housing heater
buddhafragt
Post by buddhafragt »
I build a housing for the A30 with a hater.
Is there a way to switch the heater with a GCODE command... or does the A30 have a extra output at the mainbord to switch a relay?
Greetings, Michael
Re: switch a housing heater
Hi, if you use Repetier Host, you can use this: https://www.repetier.com/firmware/v091/
and select the temperature,and select to Enable heated bed support,Select Heater pin.
I hope this can help you.
