Anyone knows how to avoid printing the first layer or to avoid the infill in the first layer with Repetier/Cura?
I am unsing an Geeetech A10 and I need to get rid of the lines inside the text. As seen in the screenshot before slicing is ok but after slice lines appear inside the letters in text.
Any hint is much appreciated!
Thanks and regards.
Lines inside 3d text
- Printed text
- case3.jpg (158.63 KiB) Viewed 5843 times
- Text after slice
- Case2.jpg (263.12 KiB) Viewed 5843 times
- Text before slice
- case1.jpg (157.74 KiB) Viewed 5843 times
Re: Lines inside 3d text
Hi, Do you mean is it a word that wants to be hollowed out?
use higher temp.
A10 Slic3r profile: here
Yes, exactly!
Hi, It seems to be related to the model itself, and the model itself seems to show this.
