I have installed a capacitive sensor (yellow one) for auto bed leveling but I'm having a lot of problems. On the left of the bed the printer starts correctly but when it moves on the right and back the distance between bed and nozzle increases too much (I see the z axis rotating due to auto bed levelling).
I'm using marlin bugfix 1.1.x.
I tried linear, bilinear and UBL but always the same problem in the same directions.
I tried also 3d touch sensor but I had same problem.
Any suggestions?
Problem with auto leveling
simon_the_fish
Re: Problem with auto leveling
Hi, I have the same problem. I install the 3D Touch Sensor. In Marlin I follow the instructions from Geeetech and after uploading the Firmware, the Extruder drives to far after homing correctly X and Y... He drives a little bit more then the max positions (X and Y) and then he begin to probe....
In the auto bed leveling options in Control.h I can't find an option to set the first probe position.
does anyone have a solution?
simon_the_fish
Solution
For me M502; Factory Defaults and M500; Store to EEPROM works.
