A30 silent fans
TheG
A30 silent fans
Post by TheG »
Hi all!
Did anyone mod their A30 for silent fans? I've replaced the stepper drivers and now the only thing that can be heard are the incredibly loud fans in the A30 control box.
I've found this on Thingiverse: https://www.thingiverse.com/thing:3101920
I wonder if anyone is already using or or something similar and can report their experiences :) I currently plan to use the above thingiverse part, remove all A30-control box fans and use 2 x 120mm ultra silent arctic fans to for cooling...
Re: A30 silent fans
Hi, you can judge the speed by the sound of the cooling fan in the power box.
TheG
Re: A30 silent fans
Post by TheG »
I'm slightly confused as the answer appears to have nothing to do with my question... :)
Bps
Re: A30 silent fans
Post by Bps »
I have the same issue here! brand new A30 and the Fans are very loud.
Also the Panel where you can set up the Fanspeed is not working.
So i check the Fans inside the Box and think there are 12V Fans operating on 24V. To deal with this i solder some resitors serial insde each Fans Kabel. So Fans are silent now!
Check what kind of Fans are inside and test which one causes the may Noise. Best way is to check Voltage and Current on this and put and resistor serial...
Hope this helps...
slipknot28
Re: A30 silent fans
Post by slipknot28 »
I am using something similar. I remixed CR10 fan case with two 120 mm fans, but i didn't disconnected all fans.
I just disconnected power fan and removed power supply cover.
http://www.thingiverse.com/thing:3712312
Best regards
