Hi, my i3 pro b finished a 7 hour print but when I tried to home it the Y axis moved away from its endstop and crashed into the frame. How can I get this back to normal and why do you think it happened?
Ron
y axis problem
Re: y axis problem
Hi, You can use the slicing software to test it, as follows:viewtopic.php?f=17&t=60927
Then check the driver board voltage (0.8-1.2V).
