X OR Y NOT MOVING
Posted: Fri Jul 19, 2019 5:57 am
I don't know what I did but this is just not working. I have had a ROBO 3D for four years now and I thought I was familiar with 3d Printers and slicing software.If I try and print from the PC or the SD card it is setting the Z ( I have the BTL installed ) the starts to heat the bed once the bed is at temp it starts to heat the extruder. So far so good. Then is very slowly greps to the X and Y stops. When the extruder reaches temp it just sits in the stops and extrudes plastic . If I try and move the X from the PC manually it won't move the Y will let me move it one time in the positive direction. I can move the X and Y from the control on the printer. If this was really tested before it was shipped then I hooked some thing up very wrong, Can anyone help me.
