Easyprint 1.2.6 new bug discovered
Kibo
Post by Kibo »
Hallo there,
I am currently experimenting with different support settings. There I noticed a bug (I think):
Eaysyprint 1.2.6 --> Slicing Settings --> Parameters (---> enable support) --> Z distance:
This parameter seems to define the distance between the actual print and the support. The default setting is 0,1 mm. However, entered values <1mm do not have any effect. Only parameters >1mm (which are definitely not practical) have an actual effect.
Can anyone confirm this issue?
Kind regards
René
Re: Easyprint 1.2.6 new bug discovered
Thanks for your feedback. :D
Tomyuan
Post by Tomyuan »
William wrote: Tue Jul 23, 2019 9:15 am Thanks for your feedback. :D
Hi willliam, why not try it at first?
You can check the software fast and he just wants an answer.
:D , I have tried it, it can be set.
Tomyuan
Post by Tomyuan »
Hi, William.
You can try to set it to different values.
Then import the stl file and click slice.
Compare them then you will mean what I am talking about. ;)
OH, you can observe the distance transform I set
0.2mm
2mm
However, we set up support to ensure that the suspended parts do not fall. So can't be set too big.
Kibo
Post by Kibo »
Yes, you can set the value but it does not have any effect on the model. I also enabled support interface. I don´t know if this has any influence on it. I took a few screenshots.
Here I set the Z-distance to 1 mm. The gap is clearly visible:
Z distance 1 mm.JPG (157.43 KiB) Viewed 22732 times
Here I set the Z-distance to 0,9 mm. There should not be a large difference visible but for every value <1 mm the gap seems to be non existent.
Z distance 0.9 mm.JPG (123.89 KiB) Viewed 22732 times
And the slicer settings:
Slicer Settings.JPG (86.12 KiB) Viewed 22732 times
Kibo
Post by Kibo »
William wrote: Tue Jul 23, 2019 4:14 pm OH, you can observe the distance transform I set
Yes, I can confirm that there is a difference between values <1 mm and >1 mm but there is no difference between values <1 mm. So let´s say 0,1 mm isn´t any different to 0,9 mm.
Hi, but in fact, the support is to protect your dangling parts, so you don't need to adjust the values very much.
Kibo
Post by Kibo »
I just read a good tutorial on how to improve the print quality when using support. There they experimented with different Z distances. I would very much appreciate it, if this feature was added in a future version of easyprint.
