Currently I can only print from extruder 0 (the right sided one) but not from extruder 1. I have tried to press the PLA filament out by hand but it seems to be clogged.
I have looked in the manual for advice as well as in this forum and on Youtube, but no success.
How do I remove the clog?
A10M Clogged nozzle
Re: A10M Clogged nozzle
Hi, You can try to manually raise the nozzle temperature to 200°
and then place the consumables to see if any supplies are flowing out of the nozzle to determine if the nozzle is clogged.
If plugged, use a tool to remove the Teflon tube and use a tool to clean the nozzle. Specific operations can refer to this:https://www.youtube.com/watch?v=uKxPIGal74E
I hope this can help you.
Hi William
Thank you for your suggestion. It solved my problem, and my printer is now up and running again
