Synchronising G01 and M106 command (laser engraving)
Tparent
Post by Tparent »
Dear all,
I'm trying to synchronise the start/stop of an engraving laser.
The code looks like the following :
Code: Select all
M107 P2
G28
G0 Z50
G0 X127.6479 Y140.893923 F1200
M106 P2 S100 ; Laser ON
What is happening is the activation of the M106 P2 S100 (laser ON) just after the G28 (home completion) and therefore before the completion of the expect move to position the head :
Code: Select all
G0 Z50
All ideas are welcome
i3 B + i3 C + i3 M201 + A10 + A10m + A30
(+3 x Kossel)
Mostly PLA
Re: Synchronising G01 and M106 command (laser engraving)
:mrgreen:
Which printer are you trying to use to execute this code :?:
While working on M201 I noticed a similar discrepancy in the execution of commands. :roll:
When I was developing the test script, from time to time I was sending a message to the LCD. The effect was that all messages were performed earlier than expected.
I haven't investigated the reason for this yet. However I expect that firmware interprets some commands differently.
The puzzling thing is that so far I haven't noticed this happening during normal printing. :lol:
Did you try G1 code instead of G0?
Tparent
Post by Tparent »
Thank you for your fast answer.
Yes the printer is a M201 with a GTM32 pro VB board. I tried two version of FW (1.03 and 1.04) without improvement.
Numerous test with a lot of M and G command (delay waiting etc..) in interactive or SD card execution without finding any solution.
At the end, to avoid the laser inconvenience, I replace the M106 by M115 (display message on LCD) and confirm your diagnostics (G command execution is not performed in the same thread (or with a buggy synchronization) than main GCODE flow.
It's looking like :
- M106 (FAN ON) executed)
- "a buffer" filled with G command (until the buffer full) executed whatever they will be the M107 insert between them
- when the buffer is empty, execution of the M107
Too bad. If it is a bug, I dont believe that any support/development team is still active
Yes I tried G1
(+3 x Kossel)
Mostly PLA
Hi, Are the fans you are referring to as cooling fans?
The cooling fan needs to be turned on for heat dissipation when printing.
Tparent wrote: Mon Aug 05, 2019 3:39 am ...
I replace the M106 by M115 (display message on LCD) and confirm your diagnostics G command execution is not performed in the same thread (or with a buggy synchronization) than main GCODE flow.
You mean M117?
I'd love to see what Gcode looks like after your adjustments.
I can unofficially say that I expect good changes for M201, in some time. They will also cover firmware changes.
However, GT will no longer develop the old firmware for M201.
Once there were attempts to develop firmware. However, the project was unexpectedly terminated in strange circumstances.
If I could gather a group of advanced, trusted M201 users, I could try to do something about it. :D
William wrote: Mon Aug 05, 2019 9:53 am ...
Yes, William, you're right.
However, a colleague speaks of an alternative application.
The fan control is used for other purposes.
