A30 end stop, limit switch broke, where get a new one?
The little metal arm on my z-axis limit switch broke off. I need a replacement. The end stop on the geeetech website is red, rectangular and mentions v1.2. The one on my machine is dark blue and square. I doesn't look like it will fit (bump into motor at back).
I bought a creality end stop because it looked the same. But when I plugged it in, my machine wouldn't turn on. When I plugged the old sensor in (with the broken arm missing) the machine turned on again.
I tried soldering the actual sensor from the creality stop onto the geeetech stop but I suck at welding and the sensor no longer works - ha.
Any help would be appreciated.
Thank you.
Thank you.
Re: A30 end stop, limit switch broke, where get a new one?
I swear I did a search before posting and I didn't find anything. After I posted, I scrolled down a little and found this post - https://www.geeetech.com/forum/viewtopi ... 65&t=69001
Thank you.
Thank you.
Hi, If there is a problem with the limit switch of your z-axis endstop, you can contact your sales.
Do you have a contact number or email? Every email I've sent comes back as undeliverable.
Thank you.
Thank you.
Hi, Where did you buy from?Shaytanabyad wrote: Wed Aug 28, 2019 8:27 pm Do you have a contact number or email? Every email I've sent comes back as undeliverable.
Thank you.
If you are purchasing from an agent, you need to contact yourself;
If you purchase from here, please provide your purchase specific address, order number, email address.
I purchased it used from a neighbor.
Is this what I need or will it not fit? - https://www.geeetech.com/mechanical-end ... p-704.html
Any chance you could send me the link to what I do need? I'm really trying to get this fixed quickly.
Thank you.
Thank you.
Hi, You can contact your sales for related inquiries.Shaytanabyad wrote: Fri Aug 30, 2019 8:18 pm Any chance you could send me the link to what I do need? I'm really trying to get this fixed quickly.
Thank you.
That’s how this post began. I need someone to contact. Why can’t you tell me what part I need?
