I3 pro W firmware help
Katsuki
Post by Katsuki »
So I've soldered my headers on the mainboard for my 3d touch and i downloaded what i thought is the correct firmware but now I've got all kinds of issues so it's obviously not the correct firmware.
I have a GT2560 white main board and an i3 pro W.
Can someone link me to the correct software, not to that page fill of links cause there is too many to make sense off
Edit 1:
The problem I'm having a the minute is that when the axis drive home they don't stop on home switch, they just grind against it for X and Y axis.
Also when I send the test codes over to the 3D touch it does not respond
Edit 2:
I tested the end stops using M119 and found I had X and Y backwards on the board, so now it homes correctly for X/Y, however I still cant get the 3D touch to respond to M280 with any options and when i press the needle in it doesn't stop moving Z axis down. I'm having to reset the unit before it crashed into the bed
Re: I3 pro W firmware help
Hi, For firmware, you can refer to this option to download your own requirements
: http://www.geeetech.com/forum/viewtopic ... 20&t=17046
For how to update, you can refer to this method:
http://www.geeetech.com/forum/viewtopic ... 20&t=17181
Whether your z-axis limit switch is responsive,
or if the z-axis limit switch is installed too high,
You can try to adjust the position as appropriate.
I hope this can help you.
