Sensor misses bed
mahkingmi
Sensor misses bed
Post by mahkingmi »
I installed the 3d touch sensor and then flashed the software useing packet on geeetech website, but when i run auto level the needle will try and test in a spot that is off the bed. So the center one works, then the front, then other middle, but the first rear test point misses the bed completly. I am not sure how to fix this. Has anyone run into this problem?
Re: Sensor misses bed
Hi, Are you calibrating 3d touch? you can refer to this;http://www.geeetech.com/wiki/index.php/ ... ing_Sensor
Is the correct firmware installed?
If all of the above are correct but the hot bed is still missing,
You can provide specific videos
so that we can solve the problem better.
