Hello, I just bought a rostock 301 printer.
I installed the driver CDM V2.12.00 driver; and the repetier-host V1.6.0
My device manager says that the USB post is Com3
I copied all the settings from the manual into the repieter-host & click 'connect'
The printer cannot be connected;
what can I do?
Cannot connect printer
Re: Cannot connect printer
Hi, You may need to do the following checks:
1. You can refer to this for the corresponding driver installation
: https://www.geeetech.com/forum/viewtopi ... RlcFtWdCG4
2. When you are ready to connect the printer to the Repetier Host using USB, make sure the printer is turned on and the USB cable is connected properly. Set the baud rate to 115200.
Then connect.
I hope this can help you.
Then connect.
I'm facing same error please help me!jonhconstantine11 wrote: Mon Sep 09, 2019 3:00 pm Hello, I just bought a rostock 301 printer.
what can I do?
Hi, Have you tried to install the driver manually?markcowell23 wrote: Sun Sep 15, 2019 8:13 pmI'm facing same error please help me!jonhconstantine11 wrote: Mon Sep 09, 2019 3:00 pm Hello, I just bought a rostock 301 printer.
what can I do?
