Problems with Prusa i3 Pro W
gcrichards
Post by gcrichards »
I'm having a terrible time trying to get my Prusa i3 Pro W working. Everything assembled fine and on first time startup managed to get as far as levelling the bed but then I updated the firmware and it hasnt worked ever since. I can connect to the com port but nothing else works, motors dont move and extruder & bed dont work via PC. I tried printing from SD card and the bed heats up but thats it. Tried changing firmware, baudrates, software (Easyprint 3d and repetier host) even changed USB cables......nothing.
Would appreciate any advice, FYI im a total noob at this.
Re: Problems with Prusa i3 Pro W
Hi, Are you using Arduino version 1.0.1?
Update the firmware here: http://www.geeetech.com/forum/viewtopic ... 20&t=17046
gcrichards
Yes William sure am.
Hi, If your computer can't connect to the port properly,
You need to refer to this, manually install the serial port.
you can refer to this:https://www.geeetech.com/forum/viewtopi ... RlcFtWdCG4
and the download address: https://www.geeetech.com/download.html?download_id=40
You can try to refresh the firmware again. refer to this: http://www.geeetech.com/forum/viewtopic ... 20&t=17181
Or use cura to directly print the HEX format firmware of the official website
: https://www.geeetech.com/download.html?download_id=36
And choose setting- printer-manger printer
and update
I
gcrichards
Thanks Mate, Will give this a try tonight.
:D
gcrichards
Still got same problem, about ready to burn this thing.....
Hi, Can you provide your specific operation video?
So that we can solve the problem better.
gcrichards
not sure if I can do a video, but it just seems as though the extruder and motors have no power or something. Could it be the board?
gcrichards
Ok, Tried everything again and still nothing, think I may have wasted my money on this thing.
