Is the control box fan on the back of the unit above the power switch the same for 12V and 24V systems??
I am running the 24V system, but the fan is making some loud noises now and I have an older 12V control box that I am not using with a fan. If they are the same and interchangeable, I will swap out fan from 12V control box to 24V control box... after I get all the hot gun glue off the innards.
So does anyone know if they are the same fan?
Control box fan
Re: Control box fan
Hi, It is not recommended if the required voltage of the fan is different.
Re: Control box fan
Thats why I was wondering if the voltages for the fans are the same. I want to replace fan, but no part number or anything to order from.
