Z Axis offset issue
Katsuki
Z Axis offset issue
Post by Katsuki »
My printer wont save the Z axis offset when calibrating the 3d touch
I have eeprom enables in my config
Katsuki
Re: Z Axis offset issue
Post by Katsuki »
I've fixed this but completely disabled EEPROM settings and just having a fixed offset in the program, I'll have to change it each time I pull the extruder apart but I guess I would have to the other way also.
There is a note on the guide thread saying to try disabling the EEPROM, this should be made more noticeable, as I skipped it many a times before spotting it to give it a go.
Hi, you can use M500 to save.
