Superplate
steveski21
Superplate
Post by steveski21 »
Hi Gents & Ladies
So I have a A30 which I only purchased in July 2019 and now the Superplate is peeling up off the heatbed
Wondering if many people have had this issue and if so did they replace the Superplate or peel it off and moved on a different way ?
Re: Superplate
Hi, Are you referring to the detachment of the glass plate from the aluminum substrate?
May need to replace the glass plate.
steveski21
Re: Superplate
front left corner has stopped sticking to the heatbed
Re: Superplate
Hi,If your hot bed is a Mylar sheet plus an aluminum substrate, you can replace the Mylar.
If it is a glass plate with an aluminum substrate, it needs to be replaced as a whole.
