M201 Extruder not working properly
Re: M201 Extruder not working properly
Hello Ken.
:mrgreen:
In your case, he proposes two things:
  1. check if the bowden tube is pushed down to the very end of the throat (it must be evenly cut),
  2. conduct a test in which you will use the black filament in both extruders
    and then another white one.
For easy control, draw a line at equal intervals on each filament.
:D
I can guess that the filament used is causing problems.
Your test will show if I am right. :lol:
