Filament run-out
BobaLives
Filament run-out
Post by BobaLives »
I'm in the middle of a print and using up couple rolls with only little bit of filament left and luckily I went and checked on the print and paused it as the end of the filament was passed the runout and almost thought the extruder wheel... didn't beep or stop when past the run-out switch... anyone else have that problem? What do I need to fix or check to make sure it doesn't happen again?
Jarda3d
Re: Filament run-out
Post by Jarda3d »
Use more turns to tight filament lever in extruder driver.
Did you hear anytime step loss in extruder with clogged tip? I think that no. Like shoot from printer. If not, it is not tighted correctly - except geared drivers like Titan of course, they are like saw already.
A10 Slic3r profile: here
BobaLives
Post by BobaLives »
I thought the printer was suppose to pause and beep when the filament end went past the filament run-out...
steveski21
Post by steveski21 »
BobaLives wrote: Wed Oct 02, 2019 9:51 am I thought the printer was suppose to pause and beep when the filament end went past the filament run-out...
I know this sounds like a simple question,But do you have the filament run out sensor enabled ?
BobaLives
Post by BobaLives »
What kind of a newb do you take me for??.... no, i didn't have it turned on :lol: hahaha yes I am a newb 8-)
simple question, but a darn good one! THANK YOU Steveski21!!
