Hi everyone.
Sometime ago I bought an A30 and has been running well until we chose to print with PLA+ black from ESUN. Sadly after the 2-3 layer the nozzle gets clogged. It is weird because with other black spools or with pla's from the same brand but different colour I did not have problems. I tried raising the temperature and playing with the retraction length but no solution. Any of you that may have a recommendation to try? Thanks in advance.
Clogged nozzle in the A30 with esun pla+ black
Re: Clogged nozzle in the A30 with esun pla+ black
Hi, You can try to clean the nozzle.
Then check the situation and make sure your connection is fully connected.
Appropriately increase the temperature by 5-10° and check the situation.
Hi William. Thank you for the reply. Sadly, I´ve already done that many times. With respect to the temperatures increments, I reached 235° before giving up (I started from 200°).
