temp is too low
ericdu62
temp is too low
Post by ericdu62 »
=> i am trench ;)
Actually, print stopped because the lcd message is (look picture)
==>> TEMP IS TOO LOW....
After this message, the hothend cooldown ans print is stopped...
Do you have hello for me ?
Re: temp is too low
Hi,You can check if your hot end thermistor is fully connected.
If fully accessible, try measuring the thermistor at the hot end.
ericdu62
Re: temp is too low
Post by ericdu62 »
If thermistor disconnect, the message is différent (i have testing)
Re: temp is too low
:D Hi,If the hot-end thermistor is not connected to the screen and the display temperature should be -14°,
you can try to measure the thermistor at the hot end.
ericdu62
Re: temp is too low
Post by ericdu62 »
how to measure at the end? when I dismounted, the temperature given by the probe is equal to that of the temperature of the piece and when I put it in the fingers, it goes up ... apparently it reacts correctly ...
Re: temp is too low
:D Use a multimeter to measure the thermistor resistance at the hot end,
I am not very clear what you mean, can you provide a specific video?
So that we can solve the problem better.
YvonGeee
Re: temp is too low
Post by YvonGeee »
Eric,
Does this happens when you start printing or later during the print?
Yvon
ericdu62
Re: temp is too low
Post by ericdu62 »
hello sorry for the delay.
this happens near the end of the print. In the meantime, I changed the heating cartridge, but it is still the same
YvonGeee
Re: temp is too low
Post by YvonGeee »
it always happen, even on small prints?
Can you check your gcode to see if there is no unwanted "stop heating" code before the end?
kohefef
Re: temp is too low
Post by kohefef »
The same problem comes to me and I am still trying to fix it but couldn’t solve it. if you find the solution to this problem with mba custom paper writing service reviews then let us know because I am trying to find it and nothing happening and I want it.
