Newbie with a problem A10m
thoffmann
Post by thoffmann »
Just finished assembling my new A10m but when I turn the power on at the power supply nothing happens. screen stays blank? is it something I did?
thoffmann
Re: Newbie with a problem A10m
Post by thoffmann »
ok so I did a stupid stupid thing forgot to set the asm to 120 ugh sorry yet thanks
:D Hi,If the screen is still not lit after you turn on the printer now,
Can try:
1. Check if the power supply can be powered normally.
2. Reconnect the screen cable;
3. Check if there are three lights on the motherboard.
V3 三灯亮起的位置.jpg (1.51 MiB) Viewed 15653 times
thoffmann
Post by thoffmann »
got it working by my Y axis makes a horrible noise and skips any idea how to fix this?
Hi,Can you describe the problem specifically?
Or provide a specific video,
So that we can solve the problem better.
Jarda3d
Post by Jarda3d »
check and tight all screws...
If still, then you measure and check/set driver voltage, it is easy.
A10 Slic3r profile: here
