Geeetech A30 Z Axis is 2-3mm above the bed at the start of the print
Jimkooper
Post by Jimkooper »
I got my very first 3D printer and wanted to test it by printing the benchy. So I added the printer in cura via custom fff printer, entered the dimensions, filament size, heated bed etc. After putting in filament and leveling the bed I started the print and the printer started, but the nozzle wasn't nearly where I leveled it, but rather 2-3 mm above the plate. Obviously i canceled the print.
Did anyone have the same problem or know where this may come from? Could false settings in cura be the cause or did I fail at leveling the bed correctly? Or is it something I totally missed? revs check qld
I researched on the internet and I saw you can set an z offset value in your starting gcode. Should I just try to find a value to lower the nozzle?
Thanks for your help!
Re: Geeetech A30 Z Axis is 2-3mm above the bed at the start of the print
Hi, you may still need to adjust the hotbed;
The distance between the nozzle and the hotbed is the distance of a 70gA4 leveling paper.
Jarda3d
Post by Jarda3d »
Maybe Z axis switch is too high?
A10 Slic3r profile: here
