A10 filament feeder motor not feeding
Re: A10 filament feeder motor not feeding
When you leave the filament out of the extruder and just heat the hotend up (make sure you leave a peace of filament in the runout sensor) and then move axis extruder forward.does it then run normally?
Possible contact oxidation. Sea shipping is corrosive. Train shipping on Silky Road loose screws...
A10 Slic3r profile: here
Hi, you can check if your extruder motor is working properly for a week.
If not, you can try to swap the motor wires of the other axes to the extruder motor line for viewing.
Determine if the motor line is broken and this happens.
