Greetings,
In the manual, it's say max temperature is 240 ºC.
If I replace the heater, is possible elevate the temperature...
But the doubt is:
The heater voltage is 12v or 24v?
I see on eBay heater with 50w, 350º max temperature.
Can print nylon and PC (policarbonate) without problems.
I unknow if the board can supply 50w, maybe a external power source.
Someone have any idea?
Best regards.
change heater
change heater
My printer is: Geeetech prusa I3 A Pro 3D
Re: change heater
Re: change heater
Re: change heater
Greetings,
In ebay, have this item: https://www.ebay.com/itm/Geeetech-3D-Pr ... 2749.l2649
Specs say:
Operating temperature range: -40°C~+300°C
Cartridge Heater: 12V 40 W
Can I print nylon (need 280ºC at hot end) in my Geeetech prusa I3 A Pro 3D ?
But... In the manual is write max temperatura 250ºC.
If this hot end not suporte 280ºC, I need buy a hot end 50W, but the main controler mosft's can drive this new hot end?
Best regards.
Specs say:
Best regards.
Re: change heater
Hi, It is not recommended to print nylon consumables.
You can refer to this: https://www.simplify3d.com/support/mate ... ide/nylon/
