Printing issue: extruder seems not heating
BerlinKhan
Post by BerlinKhan »
I have an issue with the prusa i3 pro b, this is my first time using a 3d printer, so i'm not so expert.
I'm trying to print an object using the Repetier-Host, but it's stucked on Extruder Heating, and the extruder is stucked at 33°
On the led panel the temperature is 33/210
and for the hot bed is 116/64°reverse image search email checker port checker
What information can i add to know what is the problem?
Thank you
Re: Printing issue: extruder seems not heating
:D Hi, you can try to check if your wiring on the motherboard is correct and fully connected.
Check the wiring of the thermistor;
Then you can try to measure the thermistor;
If you don't have a multimeter,
you can try to unplug the hot and hot thermistor from the motherboard to see the temperature display.
If the temperature still shows high temperature,
it may be a problem on the motherboard, you may need to replace it.
If the temperature is shown as a negative value,
there may be a problem with the thermistor.
I hope this can help you.
megece6263@dmailpro.net
Post by megece6263@dmailpro.net »
BerlinKhan wrote: Sat Oct 26, 2019 4:56 am I have an issue with the prusa i3 pro b, this is my first time using a 3d printer, so i'm not so expert.
Thank you
flip the machine over. unscrew the screws that holdon the plate. Check to make sure the connector is plugged in T0. Also make sure that the two cloth covered wires are also screwed into the board. If all looks good with that also check the connectors at the extruder itself.
