I'm having trouble with my printer.
I have it assembled and everything seems in working order, except when I switch it on the screen just reads:
"Card is okay!
Start test!"
If there's no SD in it, it it reads:
"No card!
Start test"
When I press the dial it just beeps and nothing happens, and pressing the reset button doesn't seem to do anything.
I've connected it to my laptop and I can't get it to work that way either, it connects but it won't do anything when I try moving the axes, heating the bed or heating the extruder.
Has anyone here encountered this problem ? Any advice ?
Re: Has anyone here encountered this problem ?
Hi, You can check if your wiring on the motherboard is correct.
If you check the wiring is correct, you can try to use USB to connect to the printer for printing.
If it can't be printed, there may be a problem with the motherboard.
