BL TOUCH prusa i3 m201 dual extruder gtm32 Pro vb,
Ziad
Post by Ziad »
Can anyone help me how to conect bl touch to the board gtm32 vb and which software to burn, please
Re: BL TOUCH prusa i3 m201 dual extruder gtm32 Pro vb,
:mrgreen:
I can only say that:
Company firmware, firmware doesn't support this gadget.
But I'm sure you know that. :roll:
Ziad
Post by Ziad »
No, I didn't know, :shock:
So which board should I buy now :cry:
Hi.
:mrgreen:
You don't have to make any extra purchases.
Get interested in the alternative version of the firmware. ;)
Personally, I think that "automatic" levelling is not indispensable in this model.
Ziad
Post by Ziad »
Thanks a lot for your concern n all Time replying me.
Could you please please advise me, which firmware should I install.
Hi.
:mrgreen:
You can use the procedure from friend Tparent, as described in our forum. You can also try out compilations from the vert colleague.
Everything is in one topic. :D
These presentations are related to Marlin firmware version for MCU 32bit.
However, I suppose this modification will deprive you of the built-in ability to mix colors. :roll:
Ziad
Post by Ziad »
OK thanks for all info, another issue am having is, sometimes the printer stop while printing, heat temp stiil on and still connected to pc, even with sd memory card loaded, thanks to help me
:D Hi, If you print for a long time,
It is best to slice the print model and save it to the sd card for printing.
Does this happen often?
Ziad
Post by Ziad »
Yes 1 out of 6,
Even for a print of 10min,
Imagine my frustration if it was a printing of 2hrs, lots filament wasted +Time.
Have anyone having this issue
Hi.
:mrgreen:
Read the information from our subforum about the M201 model.
Two cases have been identified and resolved by me. :D
I don't know if you know but a stopped/interrupted printout can be continued. :idea:
