A20M 3 weeks old and massive issues
Delanjp
Post by Delanjp »
Bought a A20m delivered 3 weeks ago, Have had nothing but problems with it, When I set it up and printed the test print on the SD card it worked first print. Printed a few items without issues. The it started. First its stopped extruding on a color filament change. Got it going again then both filaments stopped extruding, Tried cleaning the nozzle assembly to no avail Replaced the Nozzles/mixer assembly fully with an new one. Printer did not feed filament properly through the assembly. Using Esun ABS on both filaments and it will not extrude. The extrudes are running /turning but will not push filament through the nozzle. Manually pushing the filament to no avail. Temp Set to 240DegC, Mixer set to 50/50 and extruding. the extruders turn but don't extrude.
I do not recommend this printer. It has cost me money and I cannot get it reliably working. Very disappointing with it and Geeetech
:x
Delanjp
Jarda3d
Re: A20M 3 weeks old and massive issues
Post by Jarda3d »
it is obvious problem with clogged nozzle. Geeetech give you long needle and rod for cleaning hotend. Needle is for bottom side, rod is for top side. 3 weeks are enough for huge amount of dust in hotend.
My all first prints are filament filter, see Thingiverse what you like. Use plastic bag on the spool to prevent dust collection. Geeetech should put gcode to SD card, it is zero manufactoring costs.
Then print extruder lever - supplied one is fragile and broken after 2-3 months both, but I am not standard user. Now half year with printed and still they are OK. Geeetech should put gcode to SD card, it is zero manufactoring costs too.
A10 Slic3r profile: here
JuMe
Post by JuMe »
I have noticed that the extruder levers do not press the knurled transport roller firmly enough against the thread. Therefore you should check if the lever for unlocking the filament is really heavy. If not, you can increase the contact pressure by turning the Allen screw to lings. Then check the filament feed by marking the filament with a pen in front of the extruder. The filament should now be pushed well into the opening of the extruder.
ralkas
Post by ralkas »
I have had the same Problem on both auto feeder after 3 weeks. I opened them and figured out, that the leg that pushes the roller against the gearwheel has cracks to the center fixation. In my opinion a construction weakness and a replacement will have the same Problem after 10 to 20 hours of usage. This leg must be made of Metall and not plastic.
[img]C:\Users\RKvZ\Desktop\IMG_0806.JPG[/img]
sunret
Post by sunret »
Seems like the "idler arm" is a problem area ... in fairness to Geeetech, the same thing happened on my Ender 3. There's been a lot of discussion on forum thread: "New A20M couple of problems" and some others as well.
Here's a link to page 2 of that thread:
viewtopic.php?f=108&t=69809&start=10
You'll see a post by jarda3d with 3 suggested designs (Thingverse) for printing the arm. I had success with the second one.
https://www.thingiverse.com/thing:3456879
Somewhere there's a recommendation of what to do if you have one extruder not working so you can print this part with the working extruder. It seems to not be a good thing to just leave the other entry port to the hot-end without something in it. I admit I just used my Ender 3 to print the idler arm.
I've been using my printed idler arm successfully for the A20M since my posting on Jan 9, 2020.
On the other hand, getting a factory replacement from Geeetech? Not so much success. Although I realize that it's a tough time for people in that region right now ... I'm happy if y'all stay well as you can and get back to me with a replacement part when things are more normal.
- Jay
Alex Miller
Post by Alex Miller »
A logo is an important part of your company's brand and makes a significant impact on a company's public perception. A free logo maker is one of the most important branding investments a business can make.
AshleyKirkcaldie
Post by AshleyKirkcaldie »
A professional logo designer should exhibit personality, passion, and professionalism. You want someone who has experience in your niche, research skills, flexibility, responds quickly, provides outstanding examples, and shares the design process with you.
moranmc
Post by moranmc »
Do you know diggy? This is my favorite game which can help me a lot to release stress after a long day. You can try playing in your free time
nguyentra3493
Post by nguyentra3493 »
Tha Bet is considered as the house that owns the largest and most diverse online game store. There are all forms of sports betting, attractive card games, etc. with high winning rates. Including prizes up to 5 billion VND. Please visit Tha Bet to join
