Linear advance, extruder very noisy
DzzD
Post by DzzD »
Hello, I would like to know if is that normal that the extruder make a lot of noise when Linear Advance is enabled?
PS: I am using TMC2208 on extrudeur
Re: Linear advance, extruder very noisy
:D Hi, You can provide a specific video.
So that we can solve the problem better.
DzzD
Post by DzzD »
Ok I will do that, but for now I have another problem more important. I notice that retractation seems to be a lot slower than my slicer setting 30mm/s, when I look to the extruder while printing it look more like 15 or 10 mm/s, any idea ? (Marlin 2.0)
DzzD
Post by DzzD »
thanks ! It is probably related even If I use software retract and not G10/G11.
DzzD
Post by DzzD »
It is ok !
At first I tried your latest Geeetech Marlin 2.0 release but unfortunatly it was not working better, then I realised that your latest build did not contains the modifications in planner.cpp, so I've integrated the modifications from here (https://github.com/MarlinFirmware/Marli ... 1ec2e75228) and now retraction is as fast as it should.
DzzD
Post by DzzD »
Also Linear Advance is no more noisy, don't know if it come from the latest "vert" Marlin 2.0 Geeetech release or from the patch in planner.cpp, but now it work silently
DzzD
Post by DzzD »
Another day, another problem : now one extruder stops extruding (I mean the stepper motor stop moving) with some models, and usually on first layer but it print well others biggers model, any idea ?
DzzD
Post by DzzD »
It stop at first layer, so very very small, but I can print a 30x30x30 cube without problem, also the extruders stepper drivers are both cold, wich is normal as they stop at start print, it extrude about 50mm and stop for some models, I will try your last build (does it include Mix extruder speed retraction patch ?)
DzzD
Post by DzzD »
Same problem with last build :/
Side note : LCD info screen (first screen) is buggy on latest build
DzzD
Post by DzzD »
vert wrote: Wed Nov 20, 2019 6:09 am the forum is not the ideal place for discussion the server is very slow and the posting limits prevent discussion suggest using my discord.
https://discord.gg/brq79WQ
Ok I will do that next time, I dont know Discord it will be interresting to discover.
Last post for tonight but important for user facing the same issue : I tried disabling Linear Advance and it works ! (Setting it to 0 does not work, I have disabled it in Configuration_adv.h)
