Hi All, I have a Macbook which i have stupidly updated and now it won't let me use 32bit programs so does anyone know how I can use Arduino, Version number please, to revert my firmware back to stock on my pro W. I need to do this because the genuine BL Touch has become unreliable and I would like to use the original levelling set up.
Thanks in anticipation
Woo
I3 Pro W, MAC OS Catalina & Firmware upgrade
Re: I3 Pro W, MAC OS Catalina & Firmware upgrade
Hi, If you want to update the firmware of the throw,
It can be downloaded from here: viewtopic.php?f=20&t=17046
Then refresh the firmware according to this direction: viewtopic.php?f=20&t=17181
Hi William, I have tried this but arduino 1.0.1 will not work on a mac which has been upgraded to os catalina. Is there a hex file for this firmware I could upload using Cura??
I cannot see another way of doing this
Woo
Woo
Just in case you not fixed it. Download marlin 1.1.9 from the marlinfw.org site. There is a configuration.h and configuration-adv.h in the examples folder for the i3pro. Download the firmware from Geeetech, and compare the two files. The Marlin file is setup for autoleveling. Also look at the install instructions for the auto leveler, and compare those. The only real difference is the pins.h file is not there in 1.1.9 but uses a define to set the correct pins. most of the time just comment out #define bltouch. ( \\#define bltouch ).
Marlin 1.1.9 compiles using a Mac and Arduino 1.8.5.
Eph.
Eph.
