[SOLVED] EasyPrint3D v1.2.6 crashes at startup on one machine
Softfoot
Post by Softfoot »
Hi, I have 2 machines (both 64bit capable) one is running Win 7 Pro 64bit the other Win 7 Pro 32bit.
1.2.6 installs and runs on the 64bit machine but on the 32bit machine it immeadiately crashes and windows reports that it has "stopped working".
Is this an intentional limitation or a bug ??
Repetier-Host runs fine on both systems but I need EasyPrint3d to overcome an issue with RH.
Regards,
Dave
Re: EasyPrint3D v1.2.6 crashes at startup on one machine
Hi, You can try running in admin mode.
Softfoot
Post by Softfoot »
I am already in admin mode.
The OpenGL version is 1.4 --- could that be the problem ??
I am using the embedded Video Adapter (Intel Chipset) in a Dell Optimax 755.
Dave
Hi, Can you provide your error report?
Softfoot
Post by Softfoot »
What error report do you want - it starts, displays the initial screen, and then Win 7 reports it has "stopped working" and it terminates - end of storey.
Dave
Softfoot
Re: [SOLVED] EasyPrint3D v1.2.6 crashes at startup on one machine
Post by Softfoot »
I have resolved this myself ... by fitting a newer graphics card (it has OpenGL 3.1).
If the software has a minimum requirement on something it should test for it at startup and present a warning/error rather than just crashing.
Dave
