TEMP TOO LOW
Posted: Tue Nov 19, 2019 10:16 am
by DDDude31
I have sent an email to the help service which still hasn't replied. I have an a20m printer and whenever I start the print it heats up properly, however, then goes to center, goes back to auto home and displays "TEMP TOO LOW". Therefore, I can't even start the 3d print.
Also, I have PVA as a support material and it never prints for some reason/does not extrude.
I have visited a similar forum complaint but that still did not help
The 3d printer is a very important part of my life. PLZ HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :shock:
PVA link:https://www.amazon.com/Paramount-3D-Nat ... 1574129595
Picture of Printer:
Picture #1
Picture #1
Picture #2
Picture #2
As a software I use Cura
Re: TEMP TOO LOW
Posted: Tue Nov 19, 2019 10:40 am
Hi, regarding the print temperature of the nozzle, you need to adjust it.
If your nozzle does not heat up, you need to check that your nozzle wiring is fully connected;
The thermistor at the hot end is then measured.
Re: TEMP TOO LOW
Posted: Wed Nov 20, 2019 9:04 am
by DDDude31
It heats up fine. Both plate and extruder heat up.
But then when it starts the E1 requirement drops to 0 and then it stops and displays TEMP TOO LOW.
Re: TEMP TOO LOW
Posted: Wed Nov 20, 2019 9:28 am
Hi, you can check if the thermistor wiring of your hot end is fully connected.
Re: TEMP TOO LOW
Posted: Wed Nov 20, 2019 6:39 pm
by YvonGeee
You may want to check your slicer settings...
It happens to me when I make this mistake in Cura:
I want to print with one color only, I select Ext1, then I add some support and by default sometimes it selects the other color for support, if I do not change it to same model color then I have the same issue, it prints the support and then stops heating.
Re: TEMP TOO LOW
Posted: Sun Nov 24, 2019 12:33 am
by DDDude31
Hi, this is me. Very sorry about the delay. It seems I have fixed the problem by changing the start and end gcode to what it is supposed to be for Marlin. When I start the print it works just fine but then I came downstairs and noticed that the printer head was "printing" but no filament was coming out. So, it was just floating and nothing printed. Is this just a clog in the extruder?
Re: TEMP TOO LOW
Posted: Mon Dec 07, 2020 4:18 am
by eliottger
YvonGeee wrote: Wed Nov 20, 2019 6:39 pm You may want to check your slicer settings...
Hey man! I had the same issue and I changed extruders andnow it works. I think it's because the extruder doesn't have its own hotend. Do you know how to work your way around it? help would be greatly appreciated.
Re: TEMP TOO LOW
Posted: Wed Dec 16, 2020 9:41 am
by loko_lorenzo
I had this issue but resolved it because I enabled a few different temperature settings in cura. They mustve caused the printer to have conflicting conditions but when I disabled them only leaving the core temp settings like print temp the my A10m started printing normally again. Hope this helps :idea:
Re: TEMP TOO LOW
Posted: Mon Jan 04, 2021 5:08 pm
by Rosetta
Thanks for the information. Keep sharing such informatic post. Looking for the same issue.
mymilestonecard
Re: TEMP TOO LOW
Posted: Tue Jan 05, 2021 2:01 am
by ianac2000
There is a really good youtube video by 1zRadio that explains this issue and how to resolve it
https://www.youtube.com/watch?v=N9x9de4nYI8
essentially it is an issue with the way CURA deals with multi extruders. It tries to be clever and switch the temperature down on the first extruder when using the second. As a result the temp of the (one) nozzle cools and the printer cuts out.
It can be resolved in 2 ways;
1 - set all the temps including the standby temps to the same extrusion temperature
2 - follow the guidance in the youtube video and all a post processing script to remove the code that turns off extruder 1
hope this helps
