G2 pro - warn bearings in the link-arms
VikingHighlander
Post by VikingHighlander »
Where can I get new bearings or complete arms for my Delta G2 pro?
Can I change only the ends with the bearings (with the screw/bolt into the axis-mounts and extruder-mount)? :roll:
Re: G2 pro - warn bearings in the link-arms
Hi, you can provide a specific picture.
VikingHighlander
the ball-bearings at the ends of the arms holding the extruder & fan (which moves around when printing).
These seem to be worn. There is a little slack when I wiggle them.
Hi, you refer to the: diagonal rod.
VikingHighlander
yes. Can I buy new ones?
VikingHighlander
Found another problem too.
the bearings in the pulley at the top of the y-axis belt was warn out too. see pic below.
I dont have the instructions/parts catalogue. The link to it on the forum was also dead.
can I have the pars number for this bearing aslo + a link to the instructions?
Do you sell the diagonal rods + pulley bearings?
bearings pulley belt.JPG (114.24 KiB) Viewed 19408 times
